Dead no crank
FORUMS>CHRYSLER CARS>SEBRING>
Unwatch Thread
SIMILAR THREADS
SearchAbout UsWe're a group of Chrysler automotive enthusiasts, come join us and let us know about your ride.
Privacy Policy Terms and Rules Help
Connect With UsContact Us
Forum software by XenForo™
Dead no crank
Unwatch Thread
Unameit
I have a 2008 Chrysler Sebring the wife was driving it turned a corner to go into a parking lot and the car quit, dead no crank. So I bought a new ignition switch which I was installing and I noticed that there is a wire coiled around the key housing where the signal from the key is read. It leads into the wiring harness and the skreem looks like it's been cut off where the collar would go around the key and that is where this wire is wrapped around. The skreem box is there and has 2 fine wires coming out of it where it was cut off and the other end is still plugged into the cars original pigtail for the skreem.
What is up with this?
22 minutes agoEditReport
SIMILAR THREADS
Concord 2004 - Won't crank - Intermittant
93 3.3 Caravan Crank sprocket
1990 Cherokee hard to crank
'93 Grand Voyager crank, no start
Crank and Camshaft Sensor Replacement?
Crank Case Sensor and rare stalling
2004 Intrepid 2.7 - Long crank time
- Forums
- Menu
The most common causes for a no-crank no-start are a dead battery, Faulty Starter Motor, Bad Starter Solenoid, Faulty Ignition Switch, Faulty Neutral Safety Switch, Ignition System Issues, Fuel System Issues, Faulty Crankshaft Position Sensor, Wiring and Connection Problems, and Engine Mechanical Issues.
Chrysler Forum Editor
Sep 11, 2015 03:38 PM
Jun 22, 2015 10:30 PM
May 30, 2015 09:58 AM
Mar 17, 2015 11:48 AM
Jul 11, 2013 07:58 AM
