Driver Door Lock Switch Help
2005 Chrysler Sebring Sedan - Driver side door switch does not lock and unlock the driver door. Passenger side door lock switch works fine. All locks lock and unlock via the FOB. I went to the junk yard and got a new switch and replaced it. Same result. If the FOB unlocks and locks the driver side door lock, the actuator and any fuses should be good. Searching the web I have not come across this situation. Has anyone experienced this? Thanks.
Check the wiring where it passes into the door. At that spot, it bends a little every time the door is opened and closed. Sometimes wires break from the flexing.
Originally Posted by soffenback
(Post 115348)
I have a 2002 Chrysler Sebring sedan LX |
Not sure about the speakers, but the wires in the door hinge boot break. It's pretty easy to find it, and a little more work to fix it. You can squeeze the boot back and will be able to quickly spot the broken wire, but you'll have to remove the door panel, speaker, unplug the harness and pull it back out the speaker hole to solder/repair it. I had the same issue last year when my electric actuator on the driver's door no longer worked. ... alas, now the electric lock/unlock switch is no longer working. I'm going to have to do it again.
I've met the same issue, I used to switch on the kid lock, a small lock on the side of the door, but, I don't know why and how it blocked the door at all, so I had to use the left rear door to take out my kiddo. I called a locksmith to have a look at this issue, he said it was blocked because I did not switched it to the end. Actually I still do not know what I have not done correctly, but now it works
Originally Posted by Authority924
(Post 121437)
I've met the same issue, I used to switch on the kid lock, a small lock on the side of the door, but, I don't know why and how it blocked the door at all, so I had to use the left rear door to take out my kiddo. I called a local locksmith in central london to have a look at this issue, he said it was blocked because I did not switched it to the end. Actually I still do not know what I have not done correctly, but now it works
Originally Posted by CaptainBlaze
(Post 118090)
