Drivers door is not fully closed
Hi.
Just bought 2005 Sebring. Noticed one problem. When I close the door it seems that its not fully closed, compared to rear door. My guess it might be lock? Any suggestions? Thanks a lot. |
Could be the latch not working properly or the striker needing adjustment. Could be a sign of poorly repaired collision damage. You should be able to check the operation of the latch mechanism using a screwdriver to simulate engagement with the striker plate. If the latch is woking properly, look for proper adjustment.
(Post 68410)
Moved striker bit inwards, seems to do the trick. Thanks.
