Engine Code PO442 and PO455
Am looking for some help on where to start looking and what I need to replace to cure the below situation.
These codes appear on my 02 Sebring Limited with 2.7L engine. 442 says it is a small evap leak and 455 says it is a large evap leak. They do not seem to be affecting/effecting the way the engine runs but the check engine light burns until I get tired of looking at it and reset it. It varies on the amount of time it stays out until coming back on again from several days to a matter of miles driven. Thanks in advance for your help. Bill |
evap codes are small cracked or broke lines for the gas vapor that is from gas in your tank. Look for hoses under the hood cracked and a gas cap area.
