fuel pump only turns on at crank but not ON position
2010 sebring 2.4 - is it normal for there to not be any fuel going to the rail at key ON - shouldn't the fuel pump be priming?
at crank theres fuel coming out of the line (i havent tested the pressure) but at KEY ON there is NOTHING |
The pump will prime for 1 2 seconds when key on then turn off pump will only be active when cranking.
right...what im saying is it's not priming for those 1-2 seconds....but is still activating at crank
how about we start with whats the actual issue your having with the car .
| All times are GMT -5. The time now is 03:28 AM. |
