Getting to the 6CD Deck
Old Nov 12, 2005 | 03:14 AM
SanteeSebring's Avatar
Default Getting to the 6CD Deck
New Sebring owner. I have a 98 Limited Convertible and need to take out my 6 CD Changer for repair. I was able to take off the woodgrain piece but that next peice appears to be the whole hunk around the instrument cluster. And I'm definately lost as how to get the lower console parts off. Anyone have suggestions while I'm waiting to get a manual? Also, what year...97 or 99 is closest to the model 98 year in case I can't get a 98 service manual resonabily. Thanks in advance!
Mike
Old Nov 14, 2005 | 12:03 PM
JXI101's Avatar
Default RE: Getting to the 6CD Deck
the 99 is closer... Okay, I'm going to do this as specifically as possible... Remove all screws around the deck... All of them, remove the ones that look like they hold the dash in place there, then, take the fuse box cover off and remove that screw... there may be 2 more below on either side of the steering column... Once all screws are out, grip the top part of the dash above the steering column where is curves, and pull firmly toward driver seat... should pop right out. Now, look at the CD changer, there will be the changer, and a metal plate on top of it... slide out and down, then disconnect the 12V output and the coax for the changer... you're done... good luck getting it back in... I have done this operation on my car about 6 times...
fdfever
Jan 26, 2007 12:41 AM
quattj
Jan 17, 2007 02:41 AM
fdfever
Dec 13, 2006 02:17 AM
dudeofwheels
Dec 8, 2006 02:08 AM
Lateralus
Other
Jul 4, 2005 08:40 AM
