Heated seat does not work... ??? !!!
My heateddrivers seat does not work - have checked wiring under seat and appears okay - any ideas? [:@]
Thanks a lot ! (how to change the pad ????) Felix |
RE: Heated seat does not work... ??? !!!
what year is your car? heated seat comes out by way of pulling the seat material off the seat and cutting the old wiring out.might just be a relay.does pass.side work?moe
hi moe, its a 2001 LX 2.7 !
There are different cables under the seat. How can I make a test ? Passenger side is ok ! |
https://w05.dealerconnect.chrysler.c...S/8155830e.gif
DRIVER HEATED SEAT CUSHION (CUSHION SIDE) CAV CIRCUIT FUNCTION A BL SEAT HEATER B(+) DRIVER B GN HEATED SEAT DRIVER C BK/RD SEAT TEMPERATURE SENSOR INPUT D BK/RD SEAT TEMPERATURE 5V SUPPLY cavity "A"should have battery voltage when switch is turned on.wire is blue.look under your seat for this connector,back probe after turning onswitch.if you have 12v.thru your test light.then you narrowed it to the seat.moe |
that helps. Thank you very much, Moe. I'll try it at weekend.
Best regards felix |
now I found the issue:
I had to strip the leather cover. Under the front part one canfind somewires: 2 black wires and two very fine blue wires, which go to the heat sensor. When I bypassed the two black cables, the heating worked well. So I suppose that the heat sensor was damaged. So, I dont need the heat sensor. I switch to 2, 3 or 4, thats hot enough. |
| All times are GMT -5. The time now is 06:33 AM. |
