Heated Seats
Old Oct 19, 2012 | 01:22 AM
mr_simon's Avatar
Default Heated Seats
Hi everyone!
My name is Szymon and I'm come from Poland. I have a Chrysler Sebring 2.7 V6 2004 and I have a problem with heated seats - do not work.
I found instruction, what should I check to solve the problem. I checked wirng, switch, fuse and everything is OK. The heated seats switch do not illuminate but resistance value is just like in the instruction. : Confused:
Instruction says: "If the heated seat switch numerals (1-6) do not illuminate with the ignition switch in the ON position and the heated seat switch in 1-6 positions, check the fuse that supplies the switches in the junction block."
About which fuse it and where is it located?
Old Oct 19, 2012 | 06:28 AM
Shadowed's Avatar
Hi Szymon, well, as we are neighbors (I'm from Lithuania) I'll try to help You should find the program named All Data:
ALLDATA
Also Mitchell on demand:
Mitchell 1 The First Choice of Automotive Professionals
There you will find tons of useful information. Download the schematics here. If you don't find anything - write, we will came up with solution.
Old Oct 22, 2012 | 01:07 AM
mr_simon's Avatar
Hi Shadomen, neighbor
Thanks a lot for schemes, today I will check all instruments and I will write about results.
Old Oct 22, 2012 | 11:13 AM
mr_simon's Avatar
I checked wiring with schemes, and:
I don't have voltage at pin 3 and 5 on wiring heated seat switch, therefore heated seat switch numerals (1-6) do not illuminate with the ignition switch in the ON position and the heated seat switch in 1-6 positions. I tried to find fuse in the juncion block which is responsible for illuminate switch. On the schemes it is fuse number 11 and it is OK.
Next I checked Heated Seat Module wiring and I have voltage on pin H.
Maybe the problem is in the Heated Seat Relay on the Power Distribution Center. How can I check it?
Old Oct 24, 2012 | 04:28 AM
Shadowed's Avatar
Relay checking is simple, take it out, connect a voltmeter to socket 66 and 67 pins. 67 is + and 66 is -. Turn on the heating and you should see ~12V. If you the is Voltage then Body Control Module controls the relay. Next - put a Voltmeter + to socked pin 69 and the Voltmeter - put to ground (anywhere on cars body where you can see metal). You should see ~12V always. If everything is as I said - replace the relay. Write after you check this
By the way - what is your skills in electronics? Maybe I should write everything in so small steps
Old Oct 25, 2012 | 12:51 AM
mr_simon's Avatar
Hi Shadowed!
I did what you wrote. I checked voltage on pins Heated Seat Relay. Yes, everything is allright. I have 12V on pins: 67 and 66, and 69 to ground. But on pins 67 and 66 I have 12V when I turned on the ignition without including hated seats. Without the ignition but turn on heated seats nothing happened - no 12V on pins.
From which relay or fuse voltage goes to Heats Seats Switch pins, becouse there I don't have voltage.
Old Oct 26, 2012 | 04:44 AM
Shadowed's Avatar
AS I can see from the schematics it goes from Ignition to F11 then through several junctions and to 6 pin of the switch.
Old Oct 26, 2012 | 06:17 AM
mr_simon's Avatar
Shadowed, I can not read schematics well. I did foto connector of switch:
What do you think, is there evething allright with the connector?
Old Oct 26, 2012 | 07:49 AM
Shadowed's Avatar
With this quality of pictures... Anyway, wire going from the fuse color should be RD/WT - Red and white stripe. I think I can see it in the connector. Anyway - if the connector is disconnected you should have +12V only in one pin. Or if not check the continuity between all pins and F11, also one pin must have contact at all times.
ridingr6
Dec 18, 2008 12:42 PM
dfct
Aug 14, 2007 06:03 PM
dean46304
Jun 26, 2007 10:17 PM
comports
Feb 12, 2007 06:13 PM
wifes 300m
Feb 11, 2007 01:59 PM
