Help, Moms Car does not Crank W/ HD Video of Issue...
Went to run some errands with my moms car last night and she went to use it this morning and she said it does not start..
Here are the symptoms.. I have a horn, headlights, interior lights, door locks, and my hazards.. I don't have a radio, the small computer that energizes on the dash, and no wipers and no signal lights. I cannot hear the fuel pump switch on, and when you turn the key to start the car it does nothing and there is no noises. The lights do not dim inside or the headlights. Oh and as far as the radio goes it does not come on when you turn the switch to accessories either. Here the video of the issue: Any troubleshooting help is greatly appreciated! Thanks -Edgar |
Obvious stuff first, battery, cables, fuses. Under the hood next to the fuse box is another panel, it has four relays in it. One is the ASD ( automatic shut down), why you would want your car to automatically shut down, who knows? The other is the starter relay. 8.00 from the dealer. Under 5.00 from autozone. Check cables at the starter also, pull the starter and have it tested at autozone when you get a new relay.
