High Frenquency Sound coming from inside
Old Mar 26, 2009 | 02:30 AM
TayZ776's Avatar
Default High Frenquency Sound coming from inside
Hey guys I have a problem with my 96 2.5l sebring. When I turn the engine on i get a high pitch frequency sound coming from around the back seats. Almost sounds electronic but it happens even with the stereo off. It only happens when the engine is on and not when the ignition is in any other position. Its really bugging the hell out of me and if someone can shoot me some info it'd be very much appreciated. Thanks
Old Mar 26, 2009 | 08:40 PM
Is this a convertible? Could it be the power top motor?
Only other thing back there is the fuel pump but it doesn't usually make a noise like you describe.
Old Mar 26, 2009 | 10:08 PM
TayZ776's Avatar
sorry i should of specified, its a coupe. I thought it was the fuel pump too but the one in my f150 pick up is a lot lower pitched and less piercing so it kinda threw me off.
Old Mar 28, 2009 | 10:54 AM
Pull out the rear seat and you will find an access cover on the passenger side for access to the fuel pump. With the seat out of there you should be able to hear the fuel pump clearly if that's the problem.
Old Mar 28, 2009 | 11:42 AM
dusty-schaffner's Avatar
the reason why the fuel pumps sound different is because u have a chrysler coupe and a ford pickup
Old Mar 29, 2009 | 03:02 AM
TayZ776's Avatar
Great synopsis, without your work I would of never figured that out. Keep up the fantastic detective work Sherlock. Btw I hope you don't have to much trouble hitting 65 in your Dakota, for gods sakes don't try 80 you might blow a head gasket.
Old Mar 29, 2009 | 12:22 PM
my dakota? it will hit 120 without trying
Old Mar 29, 2009 | 03:20 PM
TayZ776's Avatar
on what? Hopes and dreams?
Old Mar 29, 2009 | 03:27 PM
dont get cauky now
Old Mar 30, 2009 | 03:12 AM
TayZ776's Avatar
Then don't be a troll.
