-   -   How to replace radiator for 2003 Sebring Conv. with 2.7L.V6 ? (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/how-replace-radiator-2003-sebring-conv-2-7l-v6-4859/)
Tash Feb 20, 2008 04:21 PM
I have 2003 Sebring convertible with 2.7L. V6,
Someone,Please tell me! how to replace radiator for 2003 Sebring Conv.
CHRYSLER TECH Feb 20, 2008 11:38 PM
RE: How to replace radiator for 2003 Sebring Conv. with 2.7L.V6 ?
REMOVAL [ol][*]Disconnect negative cable from auxiliary jumper terminal. WARNING: DO NOT REMOVE PRESSURE CAP OR ANY HOSE WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR. [*]Drain cooling system (Refer to 7 - COOLING/ENGINE - STANDARD PROCEDURE).[*]Remove upper radiator crossmember (Cooling Module Mounting). CAUTION: Plastic tanks, while stronger than brass are subject to damage by impact, such as wrenches.[*]Disconnect the radiator fan electrical connector.[*]Remove radiator fan.[*]Disconnect hoses from radiator.[*]Remove screw that holds support bracket for transmission cooler tubes at left side of radiator (if equipped). CAUTION: Avoid bending the condenser inlet tube. Care should be taken not to damage radiator or condenser cooling fins. [*]Remove the air conditioning condenser attaching screws located at the front of the radiator (A/C CONDENSER MOUNTING). Disengage AC condenser from radiator. It is not necessary to discharge the air conditioning system to remove radiator.[*]Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator or condenser cooling fins during removal.[/ol]
Tash Feb 21, 2008 09:41 AM
Thank you for the infomation, however I still have some more questions.
Do I have to use Chrysler special coolant or conventional green one?Can I re-use factory hose clamp? Otherwise I will replace with screw tighten type clamp
[/ol]
moe Feb 21, 2008 02:20 PM
if you have the green stuff in the car you can use any brand,if you have the orange color coolant then stick with mopar brand.using those clamps over is not such a good idea.use screw type.watch your knuckles!!!!
