Idler pulley still squeaks after replacement
Old Jan 3, 2019 | 07:03 AM
Ob799's Avatar
Default Idler pulley still squeaks after replacement
I have a 2000 sebring jxi and have replaced the serpentine belt and idler pulley twice and the squeak returns after a few drives. Its louder than ever now. I used the correct belt and pulley both times but figured maybe the bearing for some reason had gone after the first replacement. Is there a spacer that goes behind the pulley or any other additional hardware besides the idler, bolt and one bushing? Any info would help
Old Jan 12, 2019 | 10:22 PM
nauman_mustafa's Avatar
Noise made by fan belt, when idling, not a pleasant sound new belt did not help, need ideas to correct offensive sound!
Old Jan 13, 2019 | 05:40 AM
Tigermouse's Avatar
New belts on new pulleys tend to make a squeal due to the V's not same angle ( toleranceissue ) but it will go away. try a few drops of WD40.
Old Jan 13, 2019 | 02:59 PM
Belt squeal is most often caused by an improperly tensioned belt. If it's loose it will squeal. Do NOT put WD-40 on the belt. Oil on a belt will ruin it.
Old Jan 13, 2019 | 03:17 PM
Ob799's Avatar
It was caused by a loose belt as stated. Tightened it up and squeak went away. Gotta love manual tensioners
Old Aug 5, 2019 | 01:41 PM
boatmoter's Avatar
if you have access to a stethoscope, use it to locate the squeak, if not, use a 3 ft piece of garden hose and listen for the squeak at the tensioner pulley
Old Aug 6, 2019 | 03:09 AM
Tigermouse's Avatar
Good for you.
It's like getting a new car when the noise stops
marcpilot1
Nov 1, 2019 12:55 PM
julia giron
Apr 30, 2011 03:09 AM
viffer06
Jul 6, 2009 09:21 PM
Bennybone
Nov 18, 2008 05:47 PM
mediclev
Nov 17, 2008 10:48 PM
