-   -   interior noise behind dash (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/interior-noise-behind-dash-16040/)
Laimon Oct 19, 2011 02:11 PM
Sebring 2007 V6 sedan 50k km .
Large, loud clicking noise, irregular, comes from behind dash or ignition key...can't exactly tell ..
no MIL , no codes on OBDII everything works perfectly
any ideas before I start disassembling ?
Laimon Oct 22, 2011 02:04 PM
it turns out that the noise comes from actuator, left blend actuator is travelling far.
this is very strange it happens only some time, irregular, i assume that control unit faulty ? or shall i calibrate again ?
TNtech Oct 24, 2011 12:19 AM
The little plastic gears in it are probably skipping sometimes. Hard to know for sure without watching the feedback on a scan tool.
Laimon Oct 24, 2011 12:55 PM
well it lasts about 3-4 seconds before it stops. and on OBDII no DTC was recorded a nothing came up when running HVAC test.
I can replace the actuator but I have no idea how to calibrate it, or there could be damaged control unit that is pushing the actuator too far ?
Laimon Oct 25, 2011 11:02 AM
I'm measuring voltage range +5.0 to - 5.0 V when rotating temp control knop is this voltage correct ?
should it be 0V on COLD end or HOT end when door is totally closed to evaporator or opposite to heater core ?
pls advise. i'm getting crazy here ..!
TNtech Oct 25, 2011 07:23 PM
What are you using to read the HVAC, a DRB or a generic? Try doing a capacitive discharge (unhooking and touching battery terminals together for 10-30 minutes) and when you boot back up it should go through self calibration when you start the car. I'm assuming you have Auto temp control ATC since you have the V-6 in it.
Laimon Oct 26, 2011 05:29 PM
Normal scan tool, it shows DTC if generated by HVAC without ability to calibrate actuators. and I used voltimeter to measure the voltage at actuator motor. I thought that voltage when blend door is closed to max cool or max heat should be zero.
Tomorrow i will get new actuator ( 62$ from mopar ) replace and perform capacitive discharge as you suggested.
and yes I do have ATC.
Laimon Oct 27, 2011 10:57 AM
problem resolved .. replaced actuator without calibrating by installing arm @ same place as the old actuator.
I have seen broken teeth inside old actuator.
I'm satisfied now :-D
yadog Sep 27, 2017 04:25 PM
Is performing capacitive discharge the same on V-4?
Whydidshebuythis Sep 19, 2018 04:03 AM
Help me replace mine
how did u replace it?? Did u have to take dash apart??
