Key stuck in ignition
My key isstuck in the ignitionof my2005 Sebring. It starts just fine, but will not switch down to allow me to take the key out. Any help??
RE: Key stuck in ignition
That is almost certainly a problem with the shifter interlock cable that goes between the shifter and the ignition it prevents you from removing your key unless the shifter is in park. One end of the cable is under the shifter trim and the other is at the lock cylinder under the steering column trim. You'd have to remove these to check the cable and make sure it is hooked up and adjusted properly.
Sounds right. I just replaced my 04 with an 08 Avenger (thanks to a moose) and the ignition won't go into the lock position and release the key if there is a serious problem with the car.
Try wiggling the shift lever forward and/or back to see if you can pull the key. Also try turning the steering wheel. That can jam the key too.
2008 town and countrys have the same problem
just FYI... looking for a solution that doesn't entail paying the Chrylser dealer's fees
I just replaced the shifter assembly in my 2008 Pacifica. But now the key is stuck in the ignition and shifter won't shift again. I think I need to adjust the cable that releases the shifter and key how do I adjust it? Would it be a break sensor?
Shift Cable /Adjustments
VERIFICATION 1. Place gearshift lever in gated park (P). 2. Attempt to move vehicle by rocking back and forth on level ground. If vehicle does not move, attempt to start engine. If engine starts, the park position is correct. 3. Set parking brake. 4. Turn key to on/run and depress brake pedal. Place gearshift lever in neutral (N). 5. Attempt to start engine. If engine starts in both neutral (N) or park (P), gearshift cable is adjusted properly. No adjustment is required. 6. If engine does not start in either park (P) or neutral (N), perform adjustment procedure. ADJUSTMENT 1. Park the vehicle on level ground and set the parking brake. 2. Place the gearshift lever in gated park (P) and remove ignition key. 3. Loosen the cable adjustment screw at the transaxle manual valve lever . 4. Pull the gearshift lever fully forward to the park detent position. 5. Release the park brake, then rock the vehicle to assure it is in park. Reset the park brake. 6. Tighten the cable adjustment screw to 8 N·m (70 in. lbs.). Gearshift cable should now be properly adjusted. 7. Verify adjustment by using the verification procedure. |
Really your post is really very good and I appreciate it. You write very well which is amazing. I really impressed by your thread.
