Keyless entry module location
Gents,
Finally I received my keyless entry module, but instructions tell the location is behind instruments panel .. Service manual says it's attached to BCM. want to make sure before removing anything.. how to program new remote control without DRBII tool ? Thanks |
first what kinda car is this
second u wont be able to program it with out a DRB |
it's Sebring 04 , 2.7L
Ok I'll solve programming later, but now i need to install the new module. |
REMOVAL
Disconnect the remote battery negative cable from the terminal on the shock tower. The Junction Block and Body Control Module (BCM) are attached to each other. After removal they can be separated. Open the front driver's door and remove end cap. Remove instrument panel outboard bezel (Refer to 23 - BODY/INSTRUMENT PANEL/INSTRUMENT PANEL TRIM - REMOVAL). Remove instrument panel center bezel (Refer to 23 - BODY/INSTRUMENT PANEL/INSTRUMENT PANEL CENTER BEZEL - REMOVAL). Remove instrument panel inboard bezel (Refer to 23 - BODY/INSTRUMENT PANEL/INSTRUMENT PANEL TRIM - REMOVAL). Remove the left lower instrument panel trim. Remove silencer. Remove wire harness connectors from Junction Block. Remove Junction Block three mounting screws. Remove Junction Block/BCM by pulling straight down from the mounting bayonet. Disconnect BCM wire connectors and remove the assembly. Remove Junction Block/BCM from vehicle. With the Junction Block/BCM removed from the vehicle, separate the BCM from the Junction Block. Disconnect BCM from the Junction Block. Unsnap the remote keyless entry module from the BCM. NOTE: The Remote Keyless Entry (RKE) module is attached to the BCM. This must be transferred (if equipped) to the new BCM if being replaced. NOTE: If BCM is replaced, the VTSS must be enabled in the new BCM via the DRB lllŪ in order to start the vehicle |
Thanks, this is what i see in my service manual .. I got confused when I read the instructions that came along with RKE, where it shows that RKE is attached to the instruments panel ! ..
