no spark
My 1997 sebring conv v6 is not getting any spark. I think it may be the coil pack. does anyone know where it's located and the different Chrysler coil packs will interchange?
RE: no spark
I was told by the dealer the coil pack is built into the distibutar. Is this true?
RE: no spark
well its looks like its true no coil packs on your 2.5 v-6
you should check your cap and rotor though and on occasion we replace the entire distributor it is pricey you can get them aftermarket as well about half price |
RE: no spark
ok listen this a very low maintenance how ever if you bought this car new need to replace rotor in the ignicion also check if there is voltage to the distributor if not very easy take the dist off and with a 12volt tester check if any spark comes out threw coil if not cranksensor problem;)good luck buddy
