ODB codes 300-306 Sebring Lxi '97
I am receiving, and have been for nearly 2 years, random, but frequent, codes in this range. I've replaced plugs, wires, cap rotor, and valve cover gaskets (oil in sp tubes).
One thought I had was that the crankshaft position sensor may not be properly gapped. I have replaced it twice in the past, but perhaps it didn't go as planned on the last one. I can't tie a timeline directly to that repair, mostly because I'm old, can't remember, and don't keep records. So, is that a possible cause? If so, what is the proper gap? (I prefer measurements like 1-matchbook thick, 2- matchbooks thick, etc., or some other homespun gauge for the re-installation of the unit.) Another thought was the distributor. They're expensive to experiment with as a repair part, so I'm looking elsewhere first. Anyone have help? Edit: Found a gap measurement of .030 for these units. What disposable paper type items (boxes etc) may get sufficiently close to that thickness? Anybody know? |
egr vales has been knows for mulri cyl misfires
(Post 72592)
Any tests to determine whether it is a culprit? |
