over heating
my 2006 sebring convertiable with 35,000 milesover heated on thursday. it was about 8 below zero. had car towed to chrysler dealer and they cant find anything wrong with the heating system. this is what they did.
added collant fans came on at 222.8degrees thermostat operation ok upper and lower hoses get hot no leaks pressure test ok hvac system is ok find no faults with lack of heat or air out put road tested and operation is ok question is why did it over heat?? chrysler doesnt seem to know.is this a problem that is on going with sebrings? car never did put out a lot of heat till after driven for about 5miles. i asked why they didnt flush the system and replace thermostat and answer was that there tests didnt warrent it. told them the car was from florida and to check antifreeze for proper mixture thinking someone may of put wrong mixture in. anyone have any ideas or has had the same problem? thanks in advance. |
RE: over heating
From your list, it sounds like the basic culprits have been checked. The one thing that can happen in the very cold is the radiator fins being blocked by ice or snow. Is this a possibility in your situation?
