P0410 Error Code
Hey Guys
My wife and I have a 2004 Sebring sedan and we are throwing code P0410 which refers to the Secondary Air Injection System Malfunction. Does anyone know where the AIR Injection pump is located along with the fuse. Thanks |
Engine size?????
Engine size is a 2.4L
Fuse #7 in PDC / 40amp
Pump motor and relay assembly are on a metal bracket below the intake manifold. |
Ok thank-you. I read somewhere that it could be just a blown fuse. Do you know if that fuse is shared with another part/sensor. Also is there a diagram of where it is under the intake manifold just in case I do need to replace it. How hard is it to get to.
