Passenger seat stuck
My 2005 passenger seat won't move forward or backward, but the seatback will recline and move forward all the way. The release bar will move and I can see where the locking pins seem to be pulled away from the rails. Just will not slide forward so I can get a suitcase or baby seat easily loaded into the rear seat. Seat does not have even a little play in it--no movement at all. Now out of warranty, the dealer wants $85 for the diagnostic visit.
Any thoughts on where to look to locate whatever is causing the obstruction? Thanks. |
RE: Passenger seat stuck
Fairly simple to remove the seat. Bolt at each corner of seat total of 4 removed with socket. Unplug seatbelt connector and take seat out of car. Turn the seat upside down and take a look. Something could be lodged or loose. Possibly needs lubricant but unlikely.
Make sure you tighten all 4 bolts when reinstalling. If you are moderately mechanical easy job. Good luck. |
Look for coinage in the tracks. That's what I usually find.
