Passenger side window, heated seats, drivers side headlight
Old Oct 30, 2022 | 02:33 PM
Poppacoutu's Avatar
Default Passenger side window, heated seats, drivers side headlight
2012 Chrysler 200 - Pass side window will go down but not up, no heated seats, and drivers side headlight won’t come on. Any ideas? Pulled out TIPM for a couple hours to see if it would factory reset no luck.
Old Dec 22, 2022 | 07:19 PM
JtheMFC's Avatar
I was just going over the fuses yesterday that's a fuse. Pretty sure it runs all three of those. It's in the fuse box next to the steering wheel.
Old Dec 22, 2022 | 07:58 PM
JtheMFC's Avatar
Yeah I'm totally wrong I was looking at the Sebring fuse box yesterday not the 200 so what I found was under your hood there's fuse box and the driver and passenger windows are two separate fuses that are lumped together like like a plastic cover that goes over and holds them rogether. Thanks for the driver side headlight, I'm having a really hard time finding information about fuse boxes. The 2015 model has three fuse boxes two under the hood and one by the steering wheel. The ones under the hood are, there's one on the driver side where the one that you know about is and there's one on the passenger side too I'm not exactly sure where because I'm having a really hard time finding any info about the fuse boxes for that car for any year. In the 2015 model the fuse for the driver side headlight is in the fuse box that's on the passenger side under the hood. And since it's not labeled on the 2012 that I can see I have to think that it's in another fuse box somewhere that you can't find. So that means that if they went out of the exact same time more than likely you had a power surge somewhere. Which leads me to suggest taking a voltmeter and checking all your relays.
DaddyD
May 3, 2020 09:49 PM
easyryder01
Mar 11, 2018 11:54 AM
ccusum21
Feb 28, 2014 11:17 PM
fullrider27
Sep 29, 2010 01:16 AM
3littlecampers
Jun 19, 2008 02:57 PM
