plug and wire upgrade
what would be the best plugs and wire upgrade 8mm+ to use in my 2004 3.0L sebring w/5 speed man. i plan to upgrade all of the ignition, even all grounds and battery wires.
RE: plug and wire upgrade
I would recomend Bosch Wires, ... but that's only because I work at pep boys, and it's a top seller. They usually have either a 2-3 year warrenty. ummm, price between $40- and $55, as far as plugs go maybe, Champion, ACDelco, or something Splitfire... you might want to check Original Equipment.. some times the dealerships will use Platnium *spelling.. Don't forget about the Ignition Rotor, and Cap... good luck!
dont buy bosch platinums for your 6g72...i had them in mine, and it didnt run well. get NGKs for plugs....as for wires, it depends on how much you want to spend, but youre not going to see any big gains from plug wires.
| All times are GMT -5. The time now is 04:01 AM. |
