pollen filter
hi guys have 2008 sebring and was wondering where the pollen filter is on this car any ideas would be helpful? cheers.
Look in your owners manual. If you don't have one, go to chrysler.com and download it for free. There you will find this:
The A/C Air Filter is located in the fresh air inlet behind the glove box. Perform the following procedure to replace the filter: 1. Open the glove box and remove all contents. 2. Push in on the sides of the glove box and lower the door. 3. Disconnect the glove box door dampener from the slot on the side of the box. This is done by grasping the dampener connector (on the outside of the box) and the end of the connector pin (on the inside of the box) with your thumb and forefinger and pulling outward while lightly lifting upward on the door with your other hand. Once disconnected, the dampener will retract underneath the instrument panel if you release it. 4. Pivot the glove box downward. 5. Disengage the two retaining tabs that secure the filter cover to the HVAC housing and remove the cover. 6. Remove the A/C Air Filter by pulling it straight out of the housing. 7. Install the A/C Air Filter with the arrow on the filter pointing toward the floor. When installing the filter cover, make sure the retaining tabs fully engage the cover. You will also find a helpful illustration. |
