Popping sound?
Hey guys, I've been getting a popping sound whenver I make a turn while the car is moving.
If the car is moving really slow, (Less than 5 MPH) then it will make it if I make a sharp noise. It sounds like it is coming from the left side (drivers side). I just recently had the suspension rebuilt. Could it maybe be the transmission thats causing the problem? |
Sounds like a CV joint.
I have a 2004 sebring sedan witch had an annoying rattling sound that was getting worse after about a month .it was getting no louder but more frequent so i checked my front end parts with a rubber hammer and found the noise.You could even say it was a knocking sound.any way what i found was that the outer right hand double ball link to the lower control arm from the sway bar was causing it.Fortuantly this joint was after market and had grease nipples in it so all i needed was to grease it up well and problem cured. Tested the car after and it is now like a new car
| All times are GMT -5. The time now is 06:46 AM. |
