Pulls left when accelerating
02 Sebring Limited Conv pulls slightly to the left when traveling down the road and you accelerate.
Five thousand miles ago the front struts and coil spring bushings were replaced. All the suspension nuts and bolts are tight. Had wife sit in car and crank it up to see if I could spot any unusual shift of suspension with car in the air. Saw nothing unusual. Can anyone tell me what I need to do to correct this situation? Thanks in Advance. |
Maybe one wheel is braking ? Check after some driving, might be very hot. But if you say that something was done to springs and and stuff it is very likely that wheels are not aligned correctly.
Check the tie-rod ends, especially on the right. A worn ball joint there would allow the right front wheel to steer left with acceleration.
