radio
while driving my 01 sebring convertible the radio just cut out. i checked the fuses and they were all fine. i brought the car to the dealership and they cant seem to figure it out. has anyone experianced this before.
RE: radio
Take the sucker back and yell at them. Prolly just got a bad radio. It's pretty cheap to replace the radio with a better aftermarket one.
RE: radio
i dont have the car back yet the dealership still has it
RE: radio
could be wiring, everyone forgets that if you have a bad ground or a wire breaks inside somewhere, guess what, not gonna work. chances are if it just all of a sudden happened, its a connection somewhere that came loose from hitting a bump or something like that.
RE: radio
they dont have gounds like older radios they ground through the CD changer on the JR body so if the radio goes out via bad ground the cd changer will as well. The radio would more then likely have an internal defect.
RE: radio
does his car have a cd changer? didnt say anything about that. he just said the radio went out all of a sudden. and all radios use wires which can and do break occasionally or a connection can go bad. just because it goes out doesnt mean it can only be a bad radio.
RE: radio
are u a chrysler tech?
RE: radio
not a chrysler tech no, just a normal everyday technician that normally works on chevys and fords. if i was wrong to try to give him some simple suggestions (check wiring and connections) then im sorry, but i thought this forum was to try to helppeople in the way you know how to. I dont have his car to check it, so i offered some starting points before concluding that the radio is in fact, shot.
