Rear passenger window not working
Ok, so I just got a 2002 Sebring limited. When I put the (convertible) top down, the passenger rear window doesn't go down. The other windows do go down partially. This is the first Chrysler convertible I've had. I am wondering how hard is it to replace the window motor.
Or, could the window not be operating due to a bad switch. Would it be a bad switch on the drivers door panel or the switch on the center console (convertible top switch). Is there a way to test the power.....does each window have it's own power fuse and or circuit breaker. |
It could be the switch, the motor or the wiring in between, or it could be a mechanical problem with the regulator. There's also a module that runs all the windows down when you put the top down. And no, there is not a fuse/breaker for each window. Somebody's going to have to open things up and get in there with a tester to check for power and shorts and see what the problem is. If you're not comfortable doing it yourself, then your choice is to find a shop manual or hire somebody knowledgeable.
