Sebring 04 Fuel Filter
Hi
1-Can anyone advise the location and P/N of the fuel filter in Sebring 04 sedan LX 2.7L ? 2- How to manually program new keyless remote? thanks |
The fuel filter is built into the fuel pump. To change it, you have to remove the fuel pump, which requires dropping the fuel tank. Brilliant. I guess the idea was that they wanted to put the filter (strainer) before the pump rather than after it and with the pump built into the tank, well, there you go.
Instructions for programming a new remote can be found in the owners manual. You might be able to download one at chrysler.com, or find one on eBay. You'll need at least one working remote. Be sure to note that when you program your new remote you must program all your remotes at the same time or you will un-program the other ones. |
