Sebring 04 V6 Stall problem
Hi ,
two questions only this time :-) -Got rough idle, sebring 04, around 500rpm and sometimes engine V6, 2.7L stalls. Nothing on scanning tool and no MIL illumination. - is it possible to use 10W40 oil on my engine? Thanks |
Anybody could guess as to the cause of your rough idle, worn plugs, vacuum leak, clogged injectors, fuel filter, head gasket leak, bent valves, who knows? Check/fix cheapest things first.
As to oil, it's "possible" to use Crisco, that doesn't make it a good idea. Best bet is to stick to the manufacturer's recommendation. |
