-   -   Sebring 2001 (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/sebring-2001-a-10653/)
-kc- 01-26-2010 01:28 AM
Sebring 2001
Hi guys,
Im new here and I really need your assistance...
I am plannig to by Sebring 2001 2.7 and I am testing it for few days butit has some minor faults and the biggest is that speedometers (whole control panel) light is not working.
How to fix this? any ideas...
Thanx.
dcotter0579 01-26-2010 12:14 PM
If the bulbs are burned out, then you'll need to pull out the instrument cluster to get to them. That's a bit of a chore because you must remove the bezel surrounding the cluster first.
The bulbs are controlled by a signal from the body control computer and the dimmer on the turn signal stalk. Make sure before you do anything else that they have not been dimmed down fully by the control.
It's somewhat unlikely that they all would burn out at once, so there could be something else going on here.
-kc- 01-27-2010 05:31 AM
Thanx for help...strange thing is that complete lightning of speedometer, fuel, temerature is out but other things like ABS,hand brake,oil, etc works fine.
Is it possible that fuse has blown...I was checkin fuse box but i can not locate fuse for this.
People in Croatia are very sceptical of Chrysler and there are only few here so I can not ask someone for advice.
dcotter0579 01-27-2010 04:22 PM
Fuse 7 in the fuse block under the cover at the left end of the dashboard controls the instrument panel lights. It also controls the high beam indicator lamp. If that works, then it's not the fuse.
Those other indicator lamps you mention are controlled by fuse 11.
-kc- 01-28-2010 12:54 AM
Thanx...hope its fuse
-kc- 02-13-2010 10:48 AM
I took my car to car electrician and he told me that some kind of transformator has blown and I need to get a new one.
Can I get it online somehow? Order it from US...
dcotter0579 02-13-2010 12:56 PM
Try chryslerparts.net to look up your part, but you'll need more information than "some kind of transformator"
There is no such thing as a "transformator".
-kc- 02-13-2010 01:09 PM
He told me that it is transformator but I don't know how its called in English...
dcotter0579 02-13-2010 01:23 PM
What does it do?
-kc- 02-14-2010 03:40 PM
I just found out...its called power inverter...any chance of getting thatsomewhere?
