Sebring 2004 PCM pinouts & injector contril circuit
Hi, I have a sebring 2004 2.7L V6 with P0202 code which means the Injector #2 doesn't fire. I have checked the wires and ASD relay is fine. The last thing I need to do is to check the injector driver inside the PCM. Here are the snaps of the PCM circuitry.
https://www.dropbox.com/sh/bolcru4u6pif805/WJLfWyZCuk Can someone please tell me the pinouts for injector drivers and if known, which transistor is the driver for injector #2 here ? Thanks |
You can find pinouts in the factory shop manual. They come up every once in a while on eBay.
Have you determined that the injector itself is not to blame? |
Hi, yes i've checked all the injectors and they are all working at 100%. Switched to another cylinder position as well to make sure.
your not gonna get any one on here to give u the circuits of the PCM its a propitiatory system unless U have a shop that Chrysler sells the software to and can remain the computers no one has such info for the insides of the PCM.
did you find out what it was?
