Sebring suspension noisy
Old Jan 7, 2017 | 02:52 PM
Vision2099's Avatar
Originally Posted by Ericbo101
The latest:
- after replacing the trailing arms, definitely right side now
- relatively loud metalic creaking sound when pushing on corner of car
- got and tried stethoscope and the soapy water on the left side, found nothing
Next steps
- stethoscope, soapy water and ball joint check on right side
(that's after I finish the transaxle oil/filter change)
​​Thanks again for the help
you could also look into the CV shaft. This
has a boot over it that is filled with grease. The boot can get a crack or start slipping off causing squeeking noises. It is connected to the center of the wheel just above the lower ball joint but much bigger.
Old Jun 24, 2017 | 07:54 PM
Ericbo101's Avatar
And did it ! Thank you all for the help
So got a stethoscope but it did not help, I could not find which joint was wrong that way
Neither with soapy water but I could have tried earlier
So ended up changing the 2 lower arms (both side, one after the other as one side got fixed)
Happy
johnjofus
May 27, 2009 11:05 PM
actd
25
Mar 14, 2009 06:36 PM
davet
Feb 5, 2008 12:02 AM
ckrause333
Dec 15, 2006 08:59 PM
DanOz7Five0
Jul 26, 2006 01:43 AM
