-   -   serpentine belt on 2000 sebring (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/serpentine-belt-2000-sebring-9280/)
jimratz Sep 20, 2009 04:21 PM
how do I change a serpentine belt on 2000 sebring
dcotter0579 Sep 21, 2009 03:10 PM
Jack up the car, put it on a solid jackstand and remove the right front wheel. Remove the splash shield (inner fender) by pulling out the push-in fasteners. Now you have access to the belts. Depending on your engine, there are different tensioners, but you should be able to figure it out by looking at it. Relieve the tension and slip off the belt. As long as you are in there, you might as well replace the belt for the power steering pump at the same time.
htran2313 Sep 25, 2009 11:56 AM
belt removal
How do i take the Power steering belt off a 2000 Sebring.
i see that the serpetine belt has a tensioner but not the power steering belt. what are the steps to remove the belt. i'm not seeing any bolts to loosen to remove the belt. thanks
