-   -   sparkless (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/sparkless-1613/)
zdrag Jun 13, 2006 08:25 PM
sparkless
Newbe ?'s here I have a 97 2.4 and has no spark where do I check to see if i have power to the coil (which wire actually) ? and where is the crank sensor? and how do you check it
zdrag Jun 13, 2006 08:43 PM
RE: sparkless
sorry engine is a 2.5 v6 not a 2.4
JXI101 Jun 16, 2006 02:01 PM
RE: sparkless
follow the distributor main wire to the coil pack on the back of the engine... the distributor can be found hiding on the right side of the engine toward the back, connected to the head...
Crank sensor I believe is on the left where the main crank pulley is.. not sure on that though...
zdrag Jun 16, 2006 06:16 PM
RE: sparkless
there is no coil pack(s) coil and dizzy are on unit
but I cant find power through any of the wires going to the dist. there is one plug w/5 wires and two I know are grounds other 3 are orange, yellow, and blue the other plug has only 1 wire and it is green w/ orange stripe
any one have a wire scematic or know a site that I can get one? or know which wire should have power? it is a conv. if that matters
JXI101 Jun 21, 2006 01:26 PM
RE: sparkless
at this point, it's safe to say you are going to be working on your car a lot now... I would go ahead and invest in the haynes manual for your car... I have one, but it doesn't cover your particular year.. I think they're only like $15... They have everything you'll ever need to know about your car...
96bringlxi Jun 6, 2007 10:28 AM
RE: sparkless
if you dont have any signals comin from the cam or cran sensor your pcm will shut down feul and spark.
