Tachometer not work correctly
The Tachometer in my 1998 sebring convertible 2.5 jumbs from 1 rpm to 4 rpm randomly or sometimes works backwards anyone have an ideal what might be wrong
Don't know if your model has this or not but run a test on the instrument cluster.
YouTube - Chrysler Sebring 2003 Test Sequence That way you can see if you have a bad gauge or something is bad in the engine. Is it just the gauge or are there corresponding reactions coming from the engine when the gauge is malfunctioning? If it is just the gauge, it should be relatively easy to replace. I had a bad camshaft position sensor that had ill effects on my rpm. May be you should look into that? |
Tachometer not working
Ya I tried the instument panel test didn't help. I don't feel any problems with the engine just the tach.
| All times are GMT -5. The time now is 11:51 PM. |
