Tires will they work
Hello I would like to know if the tires will work on a 2006 Chrysler Sebring 2.7 L Sedan 4 doors , without any issues.
215\70R 16 100T 2 ON The Front Wheels 235\65R 16103 T 2 On the back Wheels I am getting then new from a friend free. Original ones are ( 205\65R 16) Factory Recommend Thanks and help will do. |
Be advised that front wheel well clearances on the Sebring are VERY tight. Anything larger than stock is likely to rub on the wheel well liner (splash shield). The previous owner of my car used a 1/2 inch socket instead of a 13 mm on a bolt head when changing out the battery (which is located behind the splash shield of the front wheel well.) The socket stuck on the bolt head and he replaced the splash shield leaving the socket in there. That little socket pushed the splash shield out enough to make it contact the tire which wore a hole right through the shield. Things are tight in there.
