-   -   trans problem!!!! (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/trans-problem-16204/)
Motor_man Nov 16, 2011 11:54 AM
trans problem!!!!
Hey guys have a trans problem on a 2001 chrysler sebring 2.7 eng trans will not shift out of low 1 (have to pull over turn car off restart sometimes trans will shift after that have a 0700 code &0605 code any advice would be helpfull!!!!! trans does not slip,trans fliud full,was thinking it could be trans control module THANK,s JAMES EAGAN
CHRYSLER TECH Nov 16, 2011 05:38 PM
605 is internal trans controller
LeoM Nov 19, 2011 11:40 AM
My 99 did the same thing and all it needed was to replace the vehicle speed sensor.
Motor_man Nov 23, 2011 02:46 PM
Thank's for the info i'll check the speed sensor
CHRYSLER TECH Nov 23, 2011 05:39 PM
I might as well give up this gig its like talking to brick walls here most of the time. Do i not have any pull around here being a Chrysler tech for 15 years?
Symptom:
P0605-INTERNAL TCM
POSSIBLE CAUSES
TCM - INTERNAL ERROR
TEST ACTION APPLICABILITY
1 If there are no possible causes remaining, view repair. All
Repair
Replace the TCM. WITH THE DRBIIIt PERFORM QUICK
LEARN AND REPROGRAM PINION FACTOR.
Perform 41TE TRANSMISSION VERIFICATION TEST - VER 1.
TNtech Nov 23, 2011 06:40 PM
I know right? LOLz
Motor_man Nov 25, 2011 12:59 PM
Another brick in the wall
Originally Posted by TNtech (Post 56300)
I know right? LOLz
Thank's for the great info/ you have been a big help!!!!HAVE A GOOD ONE!!!
