Transmission Noise?
Whenever I shift from Parked to Drive I hear a little noise, I was searching and it seems like this noise is common. But I'd figure to post here and make sure.
RE: Transmission Noise?
is it a suttle "CLUNK"?
no doesnt sound like a clunk. When I start the car and go from park to reverse sounds like a door creaking. It transfers smooth and everything just sounds weird, but I'm guessing by the research i've had that this is normal im not sure
it's the solenoid that moves that particular gear I would bet... not much you can do about it... make sure the fluid lines are solid and full... could be an air bubble in the line.. totally common... I wouldn't worry about it... just dont go in reverse with your girlfriend in the car... bad bad bad...
