-   -   Turn signals and Hazards not working (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/turn-signals-hazards-not-working-15587/)
tmizzle Aug 17, 2011 12:51 PM
I own a 2004 Chrysler Sebring LX 2.7L Engine. A few days ago I noticed that my turn signals and hazard lights are not working. The signals and hazard lights turn on once in a blue moon if I am lucky. My wipers, head lights (interior and exterior), brake lights ect... work just fine. I checked my fuses and all are fine. I bought a new combination switch and I still have the same problem. Does any one have any ideas? I noticed that there is some sort of relay on the combination switch. Would that be my turn signal relay? Any help would be appreciated. Thanks!
dcotter0579 Aug 18, 2011 08:18 PM
On the face of the multifunction switch that faces the front of the car is the "combination flasher". To remove it, slide it toward the front of the car. It controls both the turn signals and the emergency flasher. That's why it's called the "combination flasher".
Sounds like that may be the source of your troubles.
helo735 Aug 20, 2011 10:20 PM
flasher
tmizzle Aug 22, 2011 02:43 PM
Thanks for your help! I bought the flasher at a local Chrysler dealership for $25 and my hazards and turn signals work now.
helo735 Aug 22, 2011 02:54 PM
Awesome!
Glad you were able to get it fixed.
user 697820823 Aug 4, 2020 05:30 PM
I am having the same issue. I replaced the Flasher in steering column (from Autozone Novita LM470 Light Control Module) but did not fix problem. Wondering if it was the wrong part or something else wrong. Wipers work fine and fuse is good.
Any help muchly appreciated. Just purchased 4 days ago from a lot... unfortunately "as is" so I don't think they are going to be willing to fix it?? (isn't there certain safety items that must be working??)
whoops 2004 sebring limited convertible
dcotter0579 Aug 4, 2020 09:40 PM
"As is" means "as is". It's your problem now. First thing to check would be all the bulbs for the turn signals and hazard flashers. Also the fuse controlling them. When in doubt about any repair, deal with the cheapest and easiest stuff first.
user 697820823 Aug 11, 2020 07:32 PM
Fixed. Yay
