Waterpump price (new owner)
I just bought an extremely clean 05 Sebring convertible with 155K miles. I am not having any issues with it but after reading up on them I want to get the water pump replaced as a precautionary measure. I see it is a very involved job, and even though I always do my own work and am very mechanically inclined, I think I might find a mechanic to do it for me. Along with the water pump should I have anything else replaced while its getting done? What can I expect to pay for this kind of job?
I'm sorry. It has 115K miles NOT 155K
As you have already determined, replacement of the water pump requires tearing off pretty much everything on the "front" of the engine. Because of that, it doesn't really make sense to do this as a preventative maintenance project. The idea of a PM project is that you engage in a "little" work now so as to avoid doing a "lot" of work later. If the amount of work is going to be the same either way, then you're better off doing what becomes necessary when it becomes necessary. If it never becomes necessary then you're ahead of the game. Any time you tear anything apart, there's always a risk that you (or whoever does the work) might not put it back together just right (timing chains can be tricky) and cause some more serious problem to exist. (Like bent valves).
You probably are a person who regularly checks the oil. That's a good thing. If the oil starts to look like chocolate milk, then you've got a water pump problem that will need to be addressed ASAP. Then you can look at the rest of the stuff in there like the oil pump and timing chain and deal with those if necessary. |
(Post 106651)
