What relay or fuse controls the rear defrost on a 200
My rear defristddoes not work. It is either not hot enough to melt anything or the fuse isibad
The owners manual describes which fuse does what. If you don't have one you can download it from chrysler.com.
It could be something other than a fuse. Carefully inspect the defroster grid and make sure the connections are intact. You might need to use a volt/ohm meter to verify the integrity of the circuit. |
(Post 104254)
no fuse no relay the power supply comes from the TIPM itself
