Why won't my sebring gtc start???
Old 05-22-2017, 10:19 AM
TLT's Avatar
TLT
TLT is offline
Default REPLY: (starter system)
After checking I was informed nothing was changed out or replaced but the crankshaft...still has the Same flywheel and Cam shaft for the Signal between the sensors and the pcm. Thank you for that suggestion. Couldn't see the ECM PCM?
Old 05-22-2017, 10:23 AM
TLT's Avatar
TLT
TLT is offline
Default REPLY: (ignition system)
I was informed nothing was changed out or replaced but the crankshaft...still has the Same flywheel and cam shaft for the signal between the sensors and the pcm. Thank you for that suggestion. Could it be the ECM PCM or something else?
Old 05-22-2017, 12:53 PM
Not sure what you are saying. In one place, you said the cam and crank sensors were replaced, in another you said nothing but the crankshaft itself was replaced. If they replaced the sensors with the wrong ones, it might explain the problem.
Old 05-22-2017, 01:58 PM
TLT's Avatar
TLT
TLT is offline
Yes the crankshaft was damaged and replaced. Yes the sensors were replaced. I was unaware that you were including the crankshaft and cam sensors when you were referring to the ignition system. I will forward your information and have my technician / mechanic looking to it. Thank you
  #15
Old 05-22-2017, 08:15 PM
I want to know if they changed the cam tone wheel when the timing chain was replaced? if s then they installed one for a wrong PCM so they get to take it back apart and replace it with the original tone wheel aka gear.
  #16
Old 05-23-2017, 03:13 AM
TLT's Avatar
TLT
TLT is offline
Default Reply:
It has the original tone wheel/gear. That was not replaced.
TLT
05-21-2017 01:50 PM
TLT
05-21-2017 01:48 PM
CoolDaddy
09-30-2016 11:46 AM
CoolDaddy
09-25-2016 08:55 PM
scoobygeorge
11-23-2008 07:00 AM
Quick Reply: Why won't my sebring gtc start???
