-   Chrysler 300, 300C & 300C SRT-8 (https://www.chryslerforum.com/forum/chrysler-300-300c-300c-srt-8-17/)
-   -   08 300C 5.7 RWD / ABS EPS Traction Control Warning Lights (https://www.chryslerforum.com/forum/chrysler-300-300c-300c-srt-8-17/08-300c-5-7-rwd-abs-eps-traction-control-warning-lights-32564/)
300C Ya Jan 2, 2021 05:54 PM
Hello All,
Ihave a 2008 Chrysler 300C 5.7 RWD, The ABS EPS , Traction control & Check engine lights are on, .I'm not sure if they came on after I pulled a small mini cooper 200ft out of an intersection. using a tow rope hooked to my hitch..
After reading others threads recommendations
This is what ive done so far to fix....
Replaced rear wheel Hub
Replaced front and rear ABS & Speed Sensors..
Checked fuses..
Fully Charged Battery
Tried resetting system. pulling terminals off batteries for an hr. Still on..... AAAHHHHHH,,,lol
Cars overdue for inspection,
Any recommendations would be greatly appreciated.
JWhitley Jan 2, 2021 10:17 PM
You will need to have it scanned to see exactly what the codes are to see what is causing the issue .Hope this helps .
300C Ya Jan 3, 2021 01:52 PM
I will follow up soon.
Waiting on OBD Scanner just ordered..Should arrive Wends. .
FOXWELL NT510 Elite Bidirectional Scan Tool for Chrysler Dodge Jeep, Full System HVAC 4WD Obd2 Scanner with ABS Auto Bleed Battery Registeration TPMS EPB DPF Service Light Maintenance Functions etc
https://www.amazon.com/gp/product/B07XK1P8ZT/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Should of searched threads of which OBD scanner to order... Hopefully this one will work. The last one I tried said it supported my car, but didn't support the ABS function.. Returned it.
How often is it actually the ABS Control module that is bad.... will a code show a bad ABS module?
300C Ya Jan 5, 2021 08:26 PM
OBD Came a day early....1 Active code.... C102B Right Rear Wheel Speed Sensor Circuit. Have to check if the new one I put in....is bad.. or maybe dirt got onto it when i installed.....
ggoose Jan 5, 2021 08:50 PM
This link discusses the c102b code - https://www.chargerforums.com/thread...-clear.284873/
300C Ya Jan 17, 2021 05:44 PM
Fixed it with a new speed sensor... ABS, Traction Control, BAS, Lights went off after clearing the codes.
I put the new speed sensor in, turned the car on, now the brake light was on to. Thought I was going to run into the same problem... not being able to clear the codes with the scanner
But when I plugged the OBD in and scanned it, The sensor code came up stored. not active. What a relief. I cleared the stored codes. and poof.. all those trouble lights went off.
tarhealcracker Jan 18, 2021 06:55 AM
Good on you for letting us know how it sorted out..
