2005 Chrysler 300 Grille Removal
I am the owner of a 2005 Chrysler 300. I recently bought a new grille for the car to replace the stock one. It mounts exactly the same as the factory grille but I am not sure how to gain access to the bottom four screws that hold it in place. If anyone could help that would be great.Thank you,Johnny B
RE: 2005 Chrysler 300 Grille Removal
i replaced the original aswell
start at the top and work your way down then get another person to help you to pull the grill forward its all new material so it will not tear. while you undo the bottom bolts begin at the lfethand side make sure you have the right tools it will take some time. good luck take care 300cno1 |
Thanks for the advice. My question now is, if someone pulls the grille forward so that I can gain access to the bottom four screws,how or what will I use to re-insert those same four screws with the grille removed?
I had to remove my entire bumper cover to put mine in. I wasn't about to break something. My best advice, take off the bumper cover then replace grill and replace bumper cover. Only took me about an hour from start to finish.
