2006 Chrysler 300C
Hello,I have a 2006 300C Im getting ready to replace alot of the front end bushings,ball joints ect.I have noticed when Im on a level surface and looking at the front of the car that the passangers front tire is tilted in on the top of the wheel inward and the drivers side is almost straight up and down.My question would be what would cause the one to go inwards at the top of the passangers wheel ?
Sounds like you have a lot of negative camber.
On most stock suspensions, the result of negative camber can happen when the toe is not aligned. nothing a basic wheel alignment wouldnt rectify though. When doing a wheel alignment, they will adjust usually the toe and caster. Normally these will correct negative camber. If not, you may need a camber kit Good Luck |
