2007 300 touring A/C not performing well at idle
Old Aug 13, 2023 | 04:58 PM
dbtractor's Avatar
Default 2007 300 touring A/C not performing well at idle
I have a 2007 chrysler 300 touring with the single zone hvac control. I have put a new evaporator in ( it was leaking) a new compressor, and a new drier from four seasons on rock auto. I also replace the expansion valve with a denso. Now the problem I am having I believe I had before replacing these components but when at idle on fresh air and max fan I have high suction pressure and slightly low high pressure. 49 psi low and 165 high. I get around 58 degrees out of center vent. when I rev it up pressures and temps get better. i thought maybe the aftermarket ac compressor was not making enough flow or maybe I could try adjusting the expansion valve. It is properly charged. Condenser is not blocking and fan motor operates fine.
Old Aug 13, 2023 | 04:59 PM
dbtractor's Avatar
I am confident all blend doors are operating properly. i even pinched off heater core lines and had no change in temperature from center air vent.
atrdriver
11
Jun 23, 2018 03:15 PM
Dave P
Nov 18, 2017 03:05 PM
tommydjennings@comcast.net
Sep 4, 2013 06:12 PM
il_capo_dei_cattivi
Jun 9, 2011 04:19 PM
99Jxi
Jul 20, 2008 08:20 AM
