2012 Chrysler 300 - Coolant / Overheat Issue
Hello,
First time posting here as I've got an issue I hope someone here can help with. I have a 2012 300 with the 3.6 VVT engine that has 104k miles. Recently started to notice the coolant temperate running hot and loss of coolant. When the coolant was low you could here it gurgling / bubbling in the overflow reservoir. Went today to have the coolant system pressure checked which showed no coolant leaks or loss of pressure indicator potential head gasket failure. Last month I replaced the oil cooler (fun job) and the thermostat. Any ideas or suggestions on what to look at next? This one has me stumped. Appreciate any and all help. Thanks Mike |
Did you replace the thermostat before or after this problem started ? It not clear in your post. If it was before you gotta ask yourself if you got that thermostat in upside down.
Originally Posted by tarhealcracker
(Post 116472)
I replaced the thermostat and oil cooler at the same time - car has been running fine after which was a month or so ago. |
Originally Posted by carguy2077
(Post 116473)
Another thought. It's not unheard off for new thermostats to go bad and that's the easiest thing to check first.
Did you replace or test the Pressure/Radiator Cap??
Originally Posted by FIREM
(Post 116489)
Catching up here and ended up being the radiator cap. Every time the coolant was boiling the cap was loose. Quick replacement on it and so far no issues - will keep monitoring as I've only driven about 75 miles so far. Thanks for the help! ×
(Post 116464)
Hello,
First time posting here as I've got an issue I hope someone here can help with. I have a 2012 300 with the 3.6 VVT engine that has 104k miles. Recently started to notice the coolant temperate running hot and loss of coolant. When the coolant was low you could here it gurgling / bubbling in the overflow reservoir. Went today to have the coolant system pressure checked which showed no coolant leaks or loss of pressure indicator potential head gasket failure. Last month I replaced the oil cooler (fun job) and the thermostat. Any ideas or suggestions on what to look at next? This one has me stumped. Appreciate any and all help. Thanks Mike I brought mine to a mechanic tested it the same way pressure tested and nothing to be found . I bought my own tester an it was leaking 1/2 pound over 2 hours . So if they didnt hold pressure on it long it wouldn't show a leake. |
My overflow tank had a hairline crack in the neck of tank couldn't see it.
