2018 300 Intermittent Headlamp
Old Sep 19, 2025 | 07:10 AM
jamaiken's Avatar
Default 2018 300 Intermittent Headlamp
My 2018 300 has the Bi Xenon headlights. The left one is intermittent. Sometimes works, sometimes doesn’t. I bought a replacement bulb a couple of years ago, every time I go to replace it, the light is on. Any thoughts?
Old Sep 19, 2025 | 08:16 AM
tarhealcracker's Avatar
Replace it anyway and see what happens. At least then you will know if it's the bulb or the circuit.
Old Sep 30, 2025 | 12:34 PM
jamaiken's Avatar
Default Still issues
So swapping bulbs didn’t change things, and a new ballast also didn’t change things. Swapping entire housings also left side still out. Fuse is good. Any thoughts? Am I missing something?
Old Sep 30, 2025 | 09:20 PM
Wiggle the wires near the bulb see if it goes out when you do that or not.
Old Oct 1, 2025 | 03:10 PM
jamaiken's Avatar
Ok, I just did that. No luck. I also replaced the fuse, even though it showed continuity, because it had a black mark like it had been arcing. No luck. Do you think there’s also a arc on the fuse receptacle preventing a good contact? What else is in the circuit? Do you know where I can get a schematic of the headlight system?
Old Oct 2, 2025 | 04:00 PM
jamaiken's Avatar
It turns out that with HID bulbs there is both a left and right relay in the power distribution center. I swapped them with each other, no change. There doesn’t seem to be anything else in the circuit. I think the fuse box might need replacement if I can’t clean the terminals. Jiggling the fuses has no effect.
mbalfour
Oct 7, 2022 12:27 PM
motoguzzimark
Sep 16, 2022 01:09 PM
xfire04
Mar 13, 2009 06:23 AM
lukeinva
Apr 18, 2006 02:15 PM
saleensean
Feb 2, 2006 03:30 AM
