Air Condition Blows warm air
I have a 2006 Chrysler 300. I have changed out the radiator cooling fan assembly and it is fully charged with freon. I turned on the ac to the coolest setting and still get warm air, when I turn on the ac I hear the compressor click on also. Any ideas on what I might be missing?
what are the high and low side pressures?
All I did was hook up a cheap gauge and it read charge full. I did not charge the system with freon based on that?
When I turn on the AC, is the fan supposed to start immediately or does it take a few minutes.
I noticed when I turn the AC on the fan does not turn on. The fan to cool the engine will come on once it reaches a certain temp, but I have yet to see the other fan turn on? |
the fan can take up to 30 seconds to turn on once the high side pressure reaches a pressure. What was the low side reading when u have the ac on ?
Did you replace your fans because you thought they were bad?
I will have someone give me the hi and lo readings this week. I had a similar issue 2 years back and it was the cooling fan so I replaced it and that worked. I figured I bought a cheap after market and should replace it, but no change in the problem.
I did find out that even though the cheap gauge read full, I had no freon in the system? I added 2 cans and still no cold ac? |
Originally Posted by maddhatter
(Post 60881)
