Brakes rotors
When I am at high speed my front end shimmies a bit and I think my fromt rotors are warped. Does anyone have any suggestions. Thanks
RE: Brakes rotors
if u apply on the brakes when u are at high speed and u feel the shimmy and let off the breaks and it goes away then yes need your rotors turned.
RE: Brakes rotors
Try some cross-drilled/sloted rotor's, should stop, these rotor's let the heat out.
This my next up grade |
RE: Brakes rotors
I had the same problem
Took it to the dealer I was told that they have been problems with the brakes and they are replacing as customers come in a complaim about the problems. I had mine changed and haven't had a problem with the vibration I have a 2006 so warrenty covered |
RE: Brakes rotors
Has anyone ever had a problem with a clicking problem in the front brakes every time i put the brakes on theres this clicking.
RE: Brakes rotors
How long are the rotors under warrantee?
RE: Brakes rotors
I'm not sure about the warrenty
But I have a smooth ride now since they changed my rotors No more vibrating when I brake from a high speed Its a shame that they don't just notiy you when there's a problem you have to go and complain and then they say oh we know about the problem and we'll change them with the new improved rotors. So far this has happened to me twice Once with the rotors and then when the seals I was leaking tranny fluids and took it to the dealer and was told they know about and they are replacing them as the owners bring them in Crazy right |
RE: Brakes rotors
I have the same problem, left my 3330C sit for 6 weeks first time I drove it after the 6 weeks had a terrible vibration, they fixed once and this year same thing, I need help also. Is this front or back rotors??[:@]
RE: Brakes rotors
is to be a 300C in the above posting
RE: Brakes rotors
Ok I had the same problem with my 07 I bought it used,the warranty was transfered to me.they just turned the rotors, and sent me down the road. I havent had any problems with it yet. they were the front rotors!
